08-05-2005 02:26 PM
08-08-2005 05:05 PM
It sounds like the problem is not that the VI isn't running, but rather that the data it is "receiving" from MATLAB is getting messedu up. This conclusion is drawn, of course, from the fact that simulated data can successfully be written and read in LabVIEW and passed to MATLAB using the same methods. The only way to get to the bottom of this dilemma is going to be to do some good, old-fashioned troubleshooting.
Since we believe that the problem lies in MATLAB passing data to LabVIEW, the first thing you can try is putting a pause at the beginning of your LabVIEW code and creating a graph on the VI's front panel to show the data before it is written. If it is jumbled there, then you'll next want to check the data inside of MATLAB before it is passed. If that data is okay, then you've narrowed it down to the actual transfer, and you should then start making sure that you are matching the proper datatypes and formats. Hope this points you in the right direction!
Kind Regards,
