calling shared object function from Actor
I'm running an large application using Actor Framework on the cRIO-9068.  Labview 2013 SP1f2.
One of my Actors needs to call a function from a shared object .so file which I created.  I also created a wrapper vi which contains the Call Library node.  The wrapper vi is not part of any library or class.
When I add the wrapper vi to one of the methods of Actor A and deploy the app; I get an error for Actor B stating Actor Core.vi loaded with errors on the target and was closed.  Now here is where it gets interesting.
If I remove Actor B from the project, the error changes to Actor C.
If I remove the wrapper vi from Actor A, the error goes away and my application runs as expected.
If I run only the wrapper vi on the target, the shared object function executes as expected, with no errors.
I'm out of ideas.  I will try to replicate this issue on a small scale, but any help will be appreciated.
Thanks in advance,
Kevin
(2,784 Views)
Accepted by topic author kwkengineer
Looks like I fixed the problem by moving the .so to /usr/lib and running chmod 0755 /usr/lib/libfoo.so
would have been easier to fix if Deployment assigned error to the Actor actually using the library Smiley Happy
(2,773 Views)
