calling teststand sequence from labview
I currently have a TestStand sequence that calls a particular VI to perform Write/Read commands via a Serial Port interface. I am trying to create a user interface in Labview that goes ahead and calls the particular TestStand sequence. Being new to the Labview and TestStand interaction, what Labview examples are available that demonstrates this particular function I am describing?
(3,504 Views)
There are two different LabVIEW user interfaces that ship with TestStand. They are in the (quite obvious I think) folder called UserInterfaces.
edit - Specific questions should be posted to the TestStand board.
(3,498 Views)
