calling the recorded excel files
Hello
I am measuring some physical quantities and record them into excel file day by day using LabVIEW. now I want to call the recorded data for each day and find the average for each day and then I would like to sketch the variation of that quantity in each day and each month(based on the average of each day). I would be very grateful if you can please guide me
Looking Forward to recieving from You
(2,858 Views)
use the Read From Spreadsheet File VI read from your Excel Files. The LV help desribes pretty good how to use this VI.
Message Edited by teobax on 01-25-2010 03:15 AM
(2,851 Views)
Thanks for helping me; but can you please also tell me how can I find the average of the read file? because the output of read from spreadsheet.vi is 2D array.
Looking Forward to Recieving from You
(2,833 Views)
Accepted by topic author Monireh
First, if you are still using the code in your previous post, stop calling them Excel files. As you were told, you are creating a text file.
Second, you would use the Index Array function to get the row or column that you want. Just wire the result up to the Mean function.
(2,829 Views)
