camera file for MC1362
Dear all,
I use a "Mikrotron MC1362 camera" under LabVIEW. The problem is that Mikrotron MC1362 camera is
not supported by National Instruments, i.e. no specific camra-file is offered by NI for this type of camera.
Consequentely, I have to modify the camera-file for MC1302 camera to make it compatible for the MC1362.
Could anybody let me know, how I can make this modification?
Thanks in Advance,
E.F
(4,155 Views)
Modifying camera files are a pit of a pain but they are essentially a text file with a .ini like format.  The way I did this was to start with a similar camera and the 2 camera manual and compare the values for each parameter and modify the ones that have changed.  I thinks there as some sort of utility for creating new files but I never got this to work.  Also you can contact the seller of this camera they might have a camera file that they have previously used.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,144 Views)
Dear new user 2500,
thank you for your post on our webforum. You can use the camera file generator NI Camera File generator . I came across two post where the camera file of the MC 1310 was used; first discussion , second discussion .
I hope this will help you further, best regards,
Martijn S
NI Netherlands
(4,132 Views)
This camera file theoretically works for both the 1362 and 1363.
(3,588 Views)
