Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
can I communicate to two serial devives at difference baud rate?
XN
Member
03-05-2007
05:44 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Thanks for your help.
0
Kudos
Message
1
of 2
(2,386 Views)
Reply
Re: can I communicate to two serial devives at difference baud rate?
unclebump
Active Participant
03-05-2007
06:14 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Yes, if you are using two different comm ports. If on the same port, it will be kind of slow. You would need to open the comm session, transmit/receive data, close comm session. Change settings, open another session,...
1
Kudo
Message
2
of 2
(2,380 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
