can I convert Word docs to pdf using LabVIEW
I wouls like to programmatically convert hundreds of Word documents tp pdf format. can I do this through LabVIEW
thanks
(2,688 Views)
I have pdf995 installed. I can print a .doc file to the pdf995 driver and it will save it as a pdf file. It open word and acrobat. I'm not sure how you can pass filenames into the pdf application. Maybe there is an acitvex control for word or pdf995.
(2,680 Views)
