can I insert a column of array into mysql?
hello
I have a long coulmn of array of numbers. I use labsql to connect with mysql.
when I have a number, I change my number to string and then concatenate it with insert commands to insert my number to mysql table.
now, I want insert a long column of numbers to mysql but it is difficult. because for is need to does it like before.
can I insert this array as a batch and without use a "for" and as fast as possible?
Best Regards
Message 1 of 14
(10,434 Views)
@behzad1 wrote:
hello
Best Regards
Yes, you can save arrays as well.
But first- do you have to save an array such that you're able to work with any of its element in mysql?  If you don't need to do that (meaning, if you can work with reading back the whole array and then do work within LabVIEW after that), then one idea is to base64 encode your array, then send as string to save to mysql. When reading it back you'll have to reverse that process.
Make sure that your mysql table is set for correct data-type (such as BINARY, VARBINARY, BLOB, TINYBLOB. BINARY being faster) to handle the data.  That should be quite fast and you don't have to go through a for-loop of multiple sql calls.
If you need to work with any of the elements of your array while it's stored in mysql, that's more involved and it would require you to first restructure your table differently...
-BTC
New Controls & Indicators made using vector graphics & animations? Click below for Pebbles UI
Message 2 of 14
(10,405 Views)
Thank you BTC_Admin
yes, I need to use any of its element seperatly and I use some of my array to diffrent form, for example column 2 .
 now, how can I do it?
Can I change my array to this form in labview without "for"  as a new way to inser in a table?
1 9 8
3 5 6
9 8 4
 to:
(1,9,8)(3,5,6)(9,8,4)
because, (1,9,8)(3,5,6)(9,8,4) can insert easily.
I can use "," between my numbers by "Array To Spreadsheet String Function" and change it to this form:
1,9,8
3,5,6
9,8,4
but I can't add parenthesis without "for" and reshape it in a row.
Best Regards
Message 3 of 14
(10,374 Views)
Message 4 of 14
(10,362 Views)
(num1,num2)
(num3,num4)
(num5,num6)
(num7,num8)
from array num:
[num1 num2
num3 num4
num5 num6
num7 num8]
Best Regards
Message 5 of 14
(10,352 Views)
I don't see the problem with creating the INSERT. What have you tried? How big is the array? What have you tried?
Message 6 of 14
(10,349 Views)
 1,9,8
3,5,6
9,8,4
After that, replace all \r\n with )( and add ( in the beginning and ) at the end.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 14
(10,342 Views)
I'm not mean there are problem to creat INSERT. please see the attached picture. I concatenate two number like picture to insert in mysql. I add two number from an array and inset them. now, suppose, my numbers row is 2000 (2000*6). then, we need a for to repeat this command like picture or I should change my array number to this format:
(num1,num2)
(num3,num4)
(num5,num6)
(num7,num8)
and then, I use one insert command to insert result of "for" as your link suggestion.
can I change to this format by a block of labview? because it seems mysql command can't insert an array
Best Regards
Message 8 of 14
(10,336 Views)
Yamaeda
Which block do you mean?
I used "Search and Replace Pattern VI"
but it use a "for"
Best Regards
Message 9 of 14
(10,335 Views)
@behzad1 wrote:
Yamaeda
but it use a "for"
Best Regards
Yes, a single Search and Replace with Replace all=True should take care of the )( part, then a concatenate string to add the parenthesis in the beginning and end.
/Y
Qestit Systems
Message 10 of 14
(10,326 Views)
