can I install NI 9227 on NI USB-9162
Hello
I have an application where I need to measure difference in current using cRIO and log it to file
I am not familiar ith FPGA but can do it with cDAQ.i
Therefore I need to install it on NI USB-9162 which I have already.
But it did not work on my Laptop
Pleasef  tell me if it possible?
(3,103 Views)
Accepted by topic author Ihab
Ihab,
You can not install the NI 9227 on the USB-9162. It is not compatible.
The NI 9227 is only compatible with CompactDAQ or cDAQ-9172 according to the Compatibility chart here: https://www.ni.com/en/support/documentation/supplemental/08/c-series-module-and-compactdaq-compactri...
CLD | CTD
(3,083 Views)
