can I limit number of chars in a dialog string?
I need to display a dialog window, where the user can type a string.
Now I want that the string length is less than 10 characters.
Can I limit the number of chars in the string (so that the user can't insert the 11th
character)?
Thanks in advance
Using LV 7.0 on Win XP
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 1 of 12
(4,026 Views)
Hi vix,
You could catch the value change event for the string and limit the length to ten.
See attached.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Message 2 of 12
(4,013 Views)
@SandmanUK wrote:
See attached.
Could you save this vi in LV 7.0 format, please?
Vix
Using LV from 7
Message 3 of 12
(4,006 Views)
I personally like using the filters in this case... makes the display more stable.
Message 4 of 12
(4,007 Views)
Could you save attached vi in LV 7.0 format, please?
Vix
Using LV from 7
Message 5 of 12
(4,002 Views)
Hi vix,
I am attaching a vi that will help you out in restricting the number of characters to 10. But the thing is the string will take all the inputs as long as you keep typing in it. But the final output will be only 10 characters.
Regards
Sreedhar T
Sreedhar T
Message 6 of 12
(4,002 Views)
Hrmph, I would have sworn I did that... here you go
Message 7 of 12
(3,998 Views)
@SreedharT wrote:
Hi vix,
I'm sorry, but I have to ask you the same:
could you please change the vi in LV 7.0 format?
Vix
Using LV from 7
Message 8 of 12
(3,995 Views)
Thank you very much.
Very helpful
Vix
Using LV from 7
Message 9 of 12
(3,992 Views)
Hi vix,
verion 7.0 attached.
Message 10 of 12
(3,986 Views)
