can I make 3-D reconstruction of medical images with LabVIEW
Such as ultrasound images. can I use labview to make 3-D reconstruction with enough slices of ultrasound images. Furthermore, I need to see the interior structure. Is there any possibilities to complete it with labview? Thank you.
(3,851 Views)
Everything is possible. What is your LabVIEW version?
Newer versions of LabVIEW have a 3D picture control. How do you want to see the interior structure? (e.g. select an arbitrary plane and get its texture as an image? reconstruct curved surfaces e.g. with marching cubes algorithm? transparency?)
(3,836 Views)
marching cubes algorithm or others. I have newest version 8.5 with vision assistant. That's right,select an arbitrary plane and get its texture as an image.Just like the following:
(3,816 Views)
Hi.
What is your input information?
3D-Array of USound response intensity of a given (x,y) point of a given (z) plane?
Regards.
(3,804 Views)
input information are enough planes of 2d Usound images just like the following
(3,779 Views)
Take a look at this thread were I attempted to image a cubic section of a mouse tendon.
I also included code in that thread that images bubles in a fluid.
Ben
(3,754 Views)
