can I make Labview Exe which can be executed i A PC which is not having labview
hi,
 I am using lab view  7.1. Can we make a exe or installer, which can be run in a PC which is not having labview installed. If that can be done, please let me know which edition i have to use and how can i do
with Regards,
Ashok.
(2,787 Views)
Hi Ashok,
you have to use the ApplicationBuilder (which is not included in the Base/Student version). Ask your local NI representative for help - maybe you get an old LV7.1 AppBuilder, but most likely you have to upgrade to the actual version...
You can make exe for other computers. You can either build a full setup/installer routine or you just copy the exe and install the RunTimeEngine manually (more hazzle possible...).
(2,778 Views)
Under Tools-Build application or shared library, you can build your .exe
file. You also have to option to include an installer which installs the
necessary LabView dll's. I have the Pro version, however.
"budda" <x@no.email> wrote in message
news:1174290007790-493593@exchange.ni.com...
> hi,
> &nbsp;I am using lab view&nbsp; 7.1. Can we make a exe or installer, which
> done, please let me know&nbsp;which edition i have to use and how can i do
> with Regards,
> Ashok.
(2,761 Views)
Here is a link worth looking at:
Distributing Applications with the LabVIEW Application Builder
Cheers,
NathanT
(2,741 Views)
