06-17-2003 01:09 PM
06-18-2003
03:49 PM
- last edited on
07-20-2025
05:00 PM
by
Content Cleaner
The timing of the FOR loop will influence your PID control, which is a fundamental part of PID control. Acquiring data doesn't affect the PID although it could affect the timing of the loops. For instance if you only have one DAQ card you would want to have it all in one loop because you can not have two AI sessions open to the same card.
For more detailed information on PID I would recommend reading the "PID Control Toolset User Manual" which should have been installed to your machine but can also be found at : PID Control Toolset User Manual"
JR A.
Application Engineer
