I am trying to externally digitally trigger the output of a waveform on my 6711 board.
I am using Cont Generation - E-series D-Trig.vi.
In order to use that code on my non-E board (6711), I found document 1YBFBIQI. In it, it states that to use the code on my 6711, I should set trigger or gate source spec control to PFI #6.
But in my 6711 manual it states (p 4-11 WFTRIG Signal) that I can select any PFI pin as the source for WFTRIG.
I thought PFI6 had a fixed association with WFTRIG only when it is an output (as per p4-11 WFTRIG Signal). Could you please explain?
Thanks.
