can I use any simple VabView7 code vi in ver 5 labview?
(2,638 Views)
You cannot open LV7 code in LV5. You can save LV7 vi's to LV6.1 format but not 5.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,638 Views)
If it doesn't use any features of 7 that didn't exist in 5, and doesn't rely on any behaviours that changed between those versions, you could 'save for previous version' repeatedly using older versions of LabVIEW until you reached version 5 (do you mean 5.0, or 5.1?). If you don't have access to any of the intermediate versions, you might be able to ask someone on the forum who has them to kindly do this for you, or one of the NI representatives might do it. Unfortunately I only have 5.0.1 at the moment, so I can't help you!
If the code is really simple, it's probably easier to print or save the diagram and recreate it from scratch in the older version!
(2,638 Views)
That should work.
Thanks.
(2,638 Views)
