can I use "LabVIEW FPGA IP Export Utility" toolkit with unlicensed LabVIEW and FPGA Modules add-on?
Hello dear friends
I want to buy "FPGA IP EXPORT Utility" toolkit, at the moment I use unlicensed LabVIEW,
in LabVIEW FPGA IP Export Utility readme system requirements is:
  • LabVIEW 2020 Full or Professional Development Systems (32-bit or 64-bit)
  • LabVIEW 2020 FPGA Module (32-bit or 64-bit)
  • LabVIEW 2020 FPGA Compilation Tool for Vivado 2019.1
my question is:
Should I buy the licensed "LabVIEW" and "FPGA Module add-on" first before buying the "LabVIEW FPGA IP EXPORT utility"?
or I can buy the "LabVIEW FPGA IP EXPORT utility" and use this toolkit with an unlicensed LabVIEW and FPGA Module Add-on?
(1,305 Views)
My guess is that you need LabVIEW and LabVIEW FPGA to be licensed before you can use IP Export.
Best to check with NI or whoever you buy NI things from.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,282 Views)
