can I use the latest version of MAX with labview 6.0?
Problem Description :
We have an old system running LabView 6.0 and MAX4.5 with NI-DAQmx 8.7 and
NI-VISA 4.4.
We had a hard disk problem which we fixed and now MAX 4.5 with NI-DAQmx 8.7
will no longer import the configdata.nce file.
The error message is:
The following products cannot copy to the desination system:
NI-DAQmx 8.7: error code 0x80004005 (no error description available)
Continue?
OK, cancel
What can I do to get past this? Can I load the latest MAX and NI-DAQmx and
expect it to work?
Chris
NI Software :  LabVIEW  version 6.0
NI Hardware :  Select one if your issue is related to hardware device
Driver Version :
OS :  Windows XP
(2,734 Views)
http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248
You might want to double check your versions.  8.7.1 only supports back to LabVIEW 7.1 according to the chart in my link.
(2,731 Views)
I have also seen that item. None the less, its been working up until now.
Chris
(2,720 Views)
Accepted by topic author CDreike1
Maybe the .NCE file was created with an earlier version of max, then that version was installed after?
If NI responds you might be able to send the file to them to look at.
(2,714 Views)
