can an installer work on either xp or win7 or do I need two installers?
can an installer work on either xp or win7 or do I need to create 2  installers?
(2,606 Views)
Yes, you can create an installer that will run on either XP or Win7.  Does your application use any config or .ini files?  If so, you will need to pay close attention to a couple of details to make sure you don't run into any security issues.
(2,604 Views)
Do I check XP or later ?
The only conig file is from DaqMx.
(2,599 Views)
Yes, you'd check "XP or later".
For the DAQmx configuration you'd set that on the "Hardware Configuration" page.
(2,595 Views)
I see a check box for 32 bit. I guess I better check that as we .
(2,590 Views)
