can any one give me labview programme for reading data from agilent 8519C VNA
Hi
My name is vamsi. I was using Wincal for retreaving data from Agilent 8519C VNA. The problem with that is it is not taking averaging.
I would like to measure all S parameters in real and imaginary form. Can any one give Labview programme which can read all the S parameters after averaging is done.
Thaks a lot if you can help.
(2,798 Views)
Are you sure that it's an 8519C? I did a search of Agilent's site for that model number and the search came up empty.
Message Edited by Dennis Knutson on 04-05-2007 07:53 PM
(2,791 Views)
Yes, it is. But it is fine for me if you have the programme for any agilent family. i hope i can manage to retreave data out of vna after averaging.
(2,776 Views)
Hi Palukuru,
a word of wisdomSmiley Wink
a program from any agilent family will not work!
If you have the instruction manual for your mythical instrument then you should be able to write a driver to achieve your desire.
Attache the appropiate pdf file and I'll glady look at it.
xseadog
(2,772 Views)
