can any one implement Discrete wavelet transform in PDA module
the attached vi does denoising based on dwt of waveform it works perfectly on computer but it shows some error when I try to run it as a pda module as I have used a dwt block from signal processing toolkit,could anyone suggest a solution or any other alternative it uses a text file..as input.
Message 1 of 1
(2,549 Views)
