can anyone fix this vi
Hi unknown,
search for the (first) true in the array, than add one to the found column index and set this element to true...
Message 11 of 22
(1,559 Views)
Norbert i will fix the shifting out of the array later
I just need to know what i did wrong with moving to the right in the array
Message 12 of 22
(1,552 Views)
Hi unknown,
"what i did wrong"
-I would say using a second array control ("XO boolean 2") is wrong when searching a TRUE in the first one.
-Searching twice also looks wrong to me.
-Using Quotient&Remainder would eliminate the while loop for determining the bit position.
-Using all those locals seems wrong to me Smiley Wink
-Don't using highlighted execution and probes before asking in the forum may be wrong.
-Being not honest about homework stuff is considered wrong in this forum...
Message Edited by GerdW on 12-09-2009 03:04 PM
Message 13 of 22
(1,541 Views)
This unknown guy is sophomore student at BAU doing not a homework but the same project that I am doing .
Hey unknown you should reduce the use of boolean variables(organise your work and reduce loops).And change the while loop to include everything.
Smiley Tongue
Message 14 of 22
(1,524 Views)
2ayre fik b a2yre ya a5ou al sharmooooooooooota
Message 15 of 22
(1,519 Views)
Whatever this means, it is not following the netiquette. Please stop writing comments like this. This forum is meant for usage for everyone, so everyone should be able to read and understand your postings (basically). Using 1337-speech does not support this requirement. Not to consider possible offensive content in this post.......
Norbert
Norbert
Expert: Geometry
Message 16 of 22
(1,514 Views)
sorry i chose a different language character encoding so it appeared that way
i am really sorry
Message 17 of 22
(1,508 Views)
Hey unknown you should switch the terminals of the replace array subset.
Message 18 of 22
(1,508 Views)
thank u very much
Message 19 of 22
(1,502 Views)
Try this
Tim
GHSP
Message 20 of 22
(1,501 Views)
