can anyone help me with a demo for controlling a damper test rig
I am trying to build a damper endurance test rig using the arduino uno microprocessor and i'm a bit lost on it. Is anyone out there that could help me with a demo to start up with.
(2,675 Views)
... and what has this to do with LabView?
(2,668 Views)
Hi mendietta,
Could you confirm what you are trying to do and the hardware and software you are wishing to use?
Regards
Matt Surridge
(2,639 Views)
I'm trying to build a damper endurance test rig using labview for interfacing it. I'm using an arduino uno microcontroller with a shield for a dc motor which is used as the actuator.
(2,632 Views)
Ok so have you downloaded the LabVIEW Arduino tool kit?
This will allow you to interface with the Ardino.
If you post back with specific questions then I will answer them if I can.  I am unable to tell you how to build the entire system.
Matt Surridge
(2,629 Views)
