can chanel with 8473s
hi every body,
I want receive chanel from USB 8473s. With this device it's impossible to use chanel API librairi. Now i can receiv frame but i will translate this frame into chanel.
kris
(2,636 Views)
Ok, to convert frame data into channel data  you should use the CAN Frame Channel Conversion Library. More information on this KB.
Steve M.
(2,594 Views)
