can gpib query command at one time
HI all,
I now try to write a small program using Labview, my GPIB card is attached to the oscilloscope, my question is can I query 3 commads(let say:MEAS:VMIN?;MEAS:VMAX?:IDN?? at one time , and read it at one time(suppose three data)?? if can ,how to do it or if there any workaround method?? cos I try to using MAX somehow, it just give the result that for first command only.
Many thanks
william lee
(2,900 Views)
You can do what you are trying (just tried it myself with a spectrum analyser) but remember the amount of data coming back.  You'll need to set the timeout and bytes to receive sufficiently high to capture what you want/expect.
Regards
(2,885 Views)
Well, I would say that it's instrument specific whether it would work or not. Sometimes the instrument will generate a query interupted error if you don't send each query separately followed by a read.
(2,867 Views)
