Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
can i build a labview application to run on a windows ce 5.0 x86 device?
tetonedge
Member
06-09-2005
12:17 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
i am trying to build a labview application to run a custom windows ce 5.0 x86 box and i was wondering if it was possible?
thank you
derek tucker
pond engineering
derek@pondengineering.com
Derek Tucker
derek@ponengineering.com
0
Kudos
Message
1
of 2
(2,590 Views)
Reply
Re: can i build a labview application to run on a windows ce 5.0 x86 device?
TylerS
Member
06-10-2005
10:29 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
tetonedge,
There are a number of requirements that need to be met in order for an application to successfully run on a Windows CE device.
Here
is a tutorial that outlines the qualifications. Hopefully this answers your questions. Good luck!
Tyler S.
0
Kudos
Message
2
of 2
(2,578 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
