can i change the default probe from lv6.1 to the one from lv6.0?
is it possible to have a custom control/indicator come up as the default probe in lv6.1?
(2,611 Views)
I am not aware of any way to set it up and the default but you can make your own custom probe in the 6.0 form and then do add that custom control to your controls palette. Then when you select custom control you can easily select your custom control(s) from the Controls palette.
(2,611 Views)
Thats what I ended up doing. I thought it would have been cool to change the default to the new one
(2,611 Views)
