can i change the value of the discrete states in EMI_CB_CalculateResetStates?
The help of LabVIEW said that calculates the values to which to reset the states of an external model in it.But it didn`t said how to reset the discrete states in it.EMI_GetNextDiscreteStates said it can be called only within the EMI_CB_CalculateDiscreteStates function.So if the discrete states can be reset in EMI_CB_CalculateResetStates,how to do it?
THX
(2,610 Views)
What is EMI_CB_CalculateResetStates?  If I knew what you were asking about I could give a little more inteligent answer.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(2,518 Views)
it is one function of the external model interface of the Control Design & Simulation Module.when a zero crossing appears,the systom will call this function to reset states.but the help of it just tell how to reset the continues states.i want to know whether i can reset the discrete states in it.
(2,503 Views)
