can i convert labview project file into hex file ?
friends i want to convert the labview project file into hex file , there is any way to do this ?
(3,255 Views)
Accepted by topic author v.k
Yes just read the file as a string and display it in a text indicator that is set for hex display.
Ben
(3,251 Views)
then can i save that file directly as *.hex ?
(3,246 Views)
It seems you're referring to the hex files that are created by microcontroller IDEs. There is no direct way to do that with the regular LabVIEW development environment. Perhaps the Microprocessor SDK is what you're thinking of. Be prepared to get your wallet out, or visit your local bank for a loan.
Message Edited by smercurio_fc on 09-29-2009 09:01 AM
(3,244 Views)
