can i edit my program while the program is running?
With some programming languages you can pause the program while it's running, make a change to it and continue. This feature would be very usefull to me. Does anyone know a routine to accomplish this in LabView?
Dusty
Message 1 of 13
(4,661 Views)
I really know of no way of doing this, because you are either in run mode or in edit mode. You can do some debugging but not like that. If someone else out there knows of a way to do that then I would like to know also.
Joe.
"NOTHING IS EVER EASY"
Message 2 of 13
(4,651 Views)
Hello Dusty,
there's a way to do that: You can edit all those subvi's that you call by reference from a (running) main vi.
Hope this helps,
Message 3 of 13
(4,648 Views)
But if he is not calling any subvi's by reference then he cannot. lets say his code is running then he realizes he needed to add 1 instead of subtract 1 then he cannot pause the code and change this. Correct
Joe.
Message 4 of 13
(4,648 Views)
Thanks for the response,
however GerdW I do not understand what you are saying. I was looking for a way to "Pause" the program while running and edit some constant or something in the program and start it back up again.
Dusty
Message 5 of 13
(4,648 Views)
jhoskins, you got it right, thats what i want to do
Message 6 of 13
(4,646 Views)
Hello Dusty,
I have a program with some filter routines in a library. The user can select one of the filters and process data with it.
Because of the "call by reference" I can edit those filters while the main vi is running. And I can even add or delete the filters, as the main vi has a "scan" routine to check for new filters... I thought such a mechanism could be helpful to you.
Message 7 of 13
(4,638 Views)
Hey GerdW I would like to know how you did that. I would find this very useful
Joe.
Message 8 of 13
(4,633 Views)
GerdW,
Are you saying that the main.vi will not call your filter subvi until a user selects a specific vi to run?
Message 9 of 13
(4,628 Views)
The short answer, once again, is that you can't pause the VI in the middle and change a constant. You can't change code that's "running" or "waiting to run". If you want to change a value during development, you should have it as control until you've determined the proper value for it. There are ways of manipulating objects on the BD programmatically, but it's not supported by NI and you probably don't want to go into that for something as small as this.
___________________
Try to take over the world!
Message 10 of 13
(4,514 Views)
