can i export dbc file
Can i export Manually configured data in Max to DBC file? if so pls some one guide me,
Thank you,
Ranjith
(3,872 Views)
Ranjith,
MAX will allow you to export to a .ncd file, the NI CAN database filetype. If you want to create your own .dbc file you will need to use a third party editor. There is some discussion of options for that in this thread.
-Marshall R
(3,831 Views)
The real answer is NO, they dont support it and at this moment there is no code that they will point you at.
It must be a IP thing because NI wont even address it!
(3,440 Views)
