can i give input to XYgraph fron an Execel sheet?
Message 1 of 8
(3,220 Views)
yes!
If you give some more information, then we can also find out how you can do it.
Mike
Message Edited by MikeS81 on 07-17-2009 11:17 AM
Message 2 of 8
(3,219 Views)
Thanks for your reply. I am new to Labview.
I have acquired datas from my experiment and stored it in an Excel sheet. if i want to plot these datas using xy-graph in Labview, will i be able to do it.
Initially i tried using  arrays to store the x-axis and y-axis values. The thing is iam not able to change the scale of my x-axis value. ie. my x-axisvalues are in the range from 5.2 to 5.5 with a step size of 0.01. ie,5.20,5.21,5.22..............,5.49,5.50. By using the properties, i changed the scale and offset values. But i didn't see on the graph, the way how i wanted it to be displayed, ie. like  5.20,5.21,5.22..............,5.49,5.50.I tried resizing my xy-graph window , but still the problem persists.
please help me.
Message 3 of 8
(3,196 Views)
Hi 9886280463,
do you mean like this?
Mike
Message 4 of 8
(3,194 Views)
I want to display all elements starting from 5.20 , 5.21, ... , 5.49, 5.50 on the x-axis scale. I am also getting the same image, as you have sent to me.
Message 5 of 8
(3,187 Views)
Hi 988...,
do you really need all numbers? You can highlight the points if needed. Right click on the plot and select "show point".
Mike
Message 6 of 8
(3,180 Views)
Message 7 of 8
(3,176 Views)
Thankyou very much. I will try out this method.Hope i can contact you anytime for future clarifications. Thanks.
Message 8 of 8
(3,162 Views)
