can i install labview runtime engine 8.6 on windows nt
I have written an application on LV 8.6, but i would like to deploy it in my clent site which has only win NT. Is it possible?
(3,304 Views)
I guess no
(3,301 Views)
The table muks posted refers to supported OS version. So maybe it will work, maybe not. If not, you won't get support from NI.
So in general i do not recommend you to do so (even if it works), but the decision is up to you.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,285 Views)
Ok!! that means i can install run-time engine 8.6 on NT?
(3,273 Views)
I suppose you already got a very non-comital answer from norbert...:smileywink::smileytongue:
(3,270 Views)
You can give it a try..... but remember that if something weird happens.... it is not supported.
Norbert
Norbert
Expert: Geometry
(3,258 Views)
