can i make security user levels to my application
Hi to all there,
I 've creat a local domain to my computer and created users also,
and I'm making a distributable application and I want to use these users in this application on another computer which I 'll run my installer on
so can I do this on a computer that doesn't have labview and DSC run time ??
by the way I've tested my software without the users levels features and it workes fine
thanks in advance
Mahmoud Alshair
Intelligent Systems Integrator ( ISI )
System Developer
(3,121 Views)
Hai,
You can do that on a system even without LabVIEW but you should have Runtime engine installed to run ur application.
Mathan
(3,117 Views)
Hi Mathan,
I 've installed run time engine and my application is running but the security levels and the users i've created on my application not running.
I'm using a local domain on my system and i've created users also but when i run the application on another computer the secutity is not working, and it doesn't recognize the users I've created
Mahmoud Alshair
System Developer
(3,095 Views)
Where do you store your users' names & the related details?
Do you mean the default users created in the installed OS on the other PC or the ones created for your application & stored in a file?
If so, is the file stored in teh location it needs to be or see to it if it is missing?
- Partha ( CLD until Oct 2027 🙂 )
(3,086 Views)
I mean The users I've created for my application usin the local domain in labview.
which file your talking about, where do I find it and where should I save it?
thanx
Mahmoud Alshair
System Developer
(3,055 Views)
Are the other computers on the same or different subnet as the host computer?
This Knowledge Base article (KB) might also be benificial for you application.
Message Edited by BLAQmx on 04-07-2008 02:50 PM
Mark
NI App Software R&D
(3,026 Views)
