can i save data from a remote server to a client computer?
written a vi which is used to collect data and store it in a file.data colection is done on a remote system.i am able to control the front pannel frm the client using front panel control in labview 6.1 using web browser.
how can i view this data once the experiment is over.(ie the file in server)
the client and server are on WAN.
should i write it to a FTP server.
how should i go abt it,
(3,122 Views)
The easiest way is to save file into shared directory on remote PC. Then you can read this file with reading functions from "File I/O" palette. In this case you should specify path to the file for example as (in windows):
\\LocalNameOfRemotePC\C\Documents and Settings\Sithara\My Documents\sharedDir\myfile.txt
first you write the name of remote PC in local net, then disk name, and path to the file.
Good luck.
Oleg Chutko.
(3,122 Views)
hi,
my server and client PC are on WAN not on local network.
sithara
(3,122 Views)
