can i stop a timer in between
hello,
i have  a situatino where i have to monitor the time elapsed for an application but in one specific condition(say a switch toggle) i have to stop the timer and then resume the timing when the condition aborts.
how do i achieve that??
awaiting replys
thanks for the time
vijay
(3,641 Views)
vijay,
Here is an Elapsed Time VI (LV 8.0) which I use in projects which require a Pause/Resume capability. The while loop in this demo VI may be the state machine while loop in your main program. This VI can be modified to meet your exact needs.
Lynn
(3,637 Views)
thanks lynn,
ill check it out and get back to you if have any other problems with it
with regards
vijay
(3,629 Views)
hi lynn,
i have a problem im working on labview7.1 and hence not able to open the vi u have sent ,
can you help me on that
with regards
vijay
(3,621 Views)
Here is an untested 7.1 version.
Lynn
(3,616 Views)
