can it possible to display front panel of global variable during run time?
A csv file is normally just a text file and you just be able to use Read From Spreadsheet File. What function are you using and are the passwords encrypted at all?
Message 11 of 22
(2,002 Views)
Hello Shoukat,
I hope your problem is resolved. Please dont hesitate to get back to us in case of further queries.
Thanks.
Message 12 of 22
(1,972 Views)
Thank you,, i just started to use labVIEW, so i facing problem using it,,
Now i want to know how to read that csv file line by line,, i used read form spreadsheet vi, but it will giving me output in number array, but i am working with string,,
Message 13 of 22
(1,956 Views)
I don't understand your problem. There is usually no reason to read line by line. It is extremeley ineffecient to do so. You get either a 2D numeric or 2D string array out of the Read From Spreadsheet function and if you want individuals rows, work with the array.
Message 14 of 22
(1,944 Views)
thank you,, i solved this problem,, if any problem furyer comes than i will ask,, thank u
Message 15 of 22
(1,916 Views)
how th get currrent position of row selected or cursor positon in the multi-column list box in the program,, (becuse i have to delete perticulatr row from this )
thank you
Message 16 of 22
(1,897 Views)
how to get currrent position of row selected or cursor positon in the multi-column list box in the program,, (becuse i have to delete perticulatr row from this )
thank you
Message 17 of 22
(1,895 Views)
The  row selected is the value of the listbox. Yse a local varible, a property node or even better the terminal itself
Message 18 of 22
(1,881 Views)
thanks for reply
i used property node but  in that i am not getting any option to get value of selected row,, can you please tell how to do it,
  thank you
Message 19 of 22
(1,858 Views)
thank you
Message 20 of 22
(1,847 Views)
