can labview 7.0 detect a right click
Is there a way labview 7.0 can detect a right click?
(2,727 Views)
Use an event structure and use a "Mouse down" event or "Mouse down?" filter event. Inside the event case place a case structure wired to the "button" event terminal. If the "button" output is "2", the right mouse button got pressed.
You can also use the tools of the "Advanced..Input Device Control" palette.
(2,727 Views)
Here's a quick example.
(2,727 Views)
Thankyou. I figured there was a number that implied which button was clicked, I just couldn't find any documentation on it.
(2,727 Views)
