can labview recieve text from a cell phone
I was just wondering if anyone knew if there is a way for LabVIEW to recieve a command as a text message from a cell phone... or if not, if there was a way for LabVIEW to recieve a command from an email?
thanks
(2,907 Views)
The text message from the cell phone could be sent to an email address that is being monitored by LabVIEW.
Yes, LabVIEW can receive email messages.
There should be many threads on the subject.  Try searching "Labview emails".
For instance, you could use ActiveX with Labview to monitor emails within Outlook or some other email applications that support ActiveX.
R
Message Edited by JoeLabView on 10-30-2008 11:24 AM
(2,873 Views)
Here are some threads on the subject:
http://forums.ni.com/ni/board/message?board.id=170&message.id=202129&query.id=141089#M202129
This one may not be useful, but there is an example (that I have not looked at):
http://forums.ni.com/ni/board/message?board.id=170&message.id=192001&query.id=141089#M192001
Another somewhat related link.. Talks about receiving calls from a cell phone.  Not quite what you are looking for.
http://forums.ni.com/ni/board/message?board.id=170&message.id=71388&query.id=141191#M71388
But might be applicable since you did not describe your application..
(2,866 Views)
Cellphone messages are send to phone numbers, so my guess is that the only
way to get those on a PC is to use a modem. Look at the AT commands...
Wiebe.
(2,860 Views)
