can labview vis be used as a external codes in VC VB or matlab
hi all!
i will build a big system for measurment and analysis.i want to use  the VIs of the labview as external  codes in VC. Is this possible? If we can do that ,how?
(2,604 Views)
You should be able to use Labview and compile it as a DLL, then link the dll and call it from other languages
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,601 Views)
Thank you!
just now i built a dll. at the beginnig i didn't set the export VI,
prompt:   Labview: An input parameter is invalid
               Application Bulider: you must export at least on VI
when i set a export vi,it worked.
i am not sure the input and output parameters of this dll,and how to set the export VI.
For example,the add vi. how can i build a dll?
should i set the controls for adden and augend,the indicate for the result? Which VI should be
the export vi.
(2,583 Views)
