The LabVIEW DSC 7 still supports only the following tags :
Analog ; Discrete ; Discrete Array and String.
The Express VI's are not directly related to the DSC module, they are simplified VI's that allows configuration as opposed to programming (external wiring). A program using the Express VI's can write and read from tags as long as the value falls into the four categories above mentioned.
Andre Oliveira
