can not delete terminals !!
There arre two arrays in some sort of a container that I could not figure out  what kind of container it is. I can not delete
the arrays by deleting their terminals. I can only delete both of them at the same time by deleting from the front panel. I have attached a simple VI that shows the problem.  Array 1 and array2 are in the container and can not be deleted. What I have to do to put other two arrays, array3 and array4 in such a container.
(2,984 Views)
Accepted by topic author Gunay
Hi gunay,
  the problem is both arrays are some grouped arrays. You just select an array and go to reorder menu..(present at theright end on the bar which has application font option)..and select the ungroup..and therefore you can do what you want..
Thanks and regards,
srikrishnaNF
Srikrishna
(2,978 Views)
They're not in a container. They're grouped.
I don't know if it's correct to block deletion of grouped objects from the BD, but it's simple to change this - select the objects, click the Reorder button (the rightmost button on the toolbar) and select Ungroup.
___________________
Try to take over the world!
(2,977 Views)
Thank you very much srikrishnaNF , tst. I was not able to figure it out for several hours.
Gunay
(2,953 Views)
