can not make scxi-1102 work?
I use SCxi-1102  with scxi-1303 for temperature maurement. I only get a flat line reading. Please see what is wrong.
Liming
(2,918 Views)
Well this isn't a LabVIEW question so it should be posted in the Multifunction daq board, but the coffee is OK.
I'm not sure but maybe your device convert it directly to temperture (Fahrenheit/Celsius/Kelvin) in all of these scales 10 is quite cold. So try setting the max to 1000 might help
Ton
My LabVIEW Ideas
(2,914 Views)
If I set to 1000, it gives error
(2,912 Views)
What error?
And have you checked different ranges.
Ton
My LabVIEW Ideas
(2,909 Views)
It works now. A Guy did not connect thermal couple right.
(2,887 Views)
