can not save nor print "getting started with labview"
From the Evaluation pull- downs, it was impossible to save or print the manual. I had to go into your web site to search the same doc and then save and print that way.
(2,396 Views)
Are you asking for some assistance with this?
R
(2,394 Views)
Hi Adria,
The LabVIEW Getting Started Manual can also be found in the LabVIEW Manuals folder under your Start Menu Programs in pdf format.
Let me know if there is anything I can help with.
Sappster
(2,369 Views)
