can plot legend grow upward?
I'm dynamically adding plots to an XY graph. The plot legend is placed on the top, right corner of the graph by default. When I add new plots, the legend grows downward, blocking the graph. Is there a setting that I can change so that the legend will grow upward? Also, I tried to place the legend on the right hand side of the graph. This also caused a similar problem when I changed the name of the plot because the name grew to the left. Is there a possible setting change for this so that the legend will grow to the right when the text becomes longer?
Thank you,
Jae Ho
LV7.1
(2,825 Views)
Use the "Plot Bounds" property along with the Plot legend property ("LegLeft") to move the plot legend's left side to the edge of the plot after setting the plot names, colors, etc.
(2,811 Views)
That's right. I can set the position of the legend in pixels. Thank you.
(2,784 Views)
