can somebody tell me how I generate this project?
I'm trying to generate the roots of this equation an · xn + an−1 · xn−1 + . . . + a1 · x + a(0) = 0
Message 1 of 13
(4,096 Views)
This is fairly straight-forward, all you need to do is build the equation into a polynomial from an array using ascending power order i.e. x^3 - 2x^2 + 4x -9 = 0 becomes [-9, 4, 2, 1].
Once you have done that feed the array into the "Polynomial Roots.vi" in order to get an array of the roots.
Message 2 of 13
(4,076 Views)
I just started to learn labview and I really don't know how to do that polynom so please help me with a specific i.e !!
Message 3 of 13
(4,064 Views)
press 'ctl + space" and type in "Polynomial root". Either that or in the block diagram right-click the background, then go Mathematics -> Polynomial -> Poly Roots
Message 4 of 13
(4,058 Views)
Coudl you please solve that equation! I really don't get it right now!
Message 5 of 13
(4,057 Views)
Okay ! I am trying right now!
Message 6 of 13
(4,055 Views)
HMMM... I already done that!
Message 7 of 13
(4,050 Views)
You already have an array of coefficients set up within the cluster control.
Now you just need to read the help for the Polynomial Roots VI to learn how to use it and apply that array of coefficients to it.
Message 8 of 13
(4,040 Views)
If you change your output array from a DBL to a Complex double it should work better. To do this, right click the terminal for the array and go Representation -> Complex Double (CDB)
Message 9 of 13
(4,038 Views)
Message 10 of 13
(4,026 Views)
