can't bind to com port
"I am currently developing a FieldPoint system. I have a FP-1000 & FP-1001. Connected to these are 2 FP-SG-140 modules and 2 4-wire RTD modules. FieldPoint explorer sees all of the modules. I found an example LabVIEW vi that is suppose to acquire data from a single channel. When I run the vi I get the error - unable to bind to com port. I am not sure what is going on. Also what is the syntax for wiring the iak file name. Is that the file path i.e. C:\...\test.iak?
Thanks for any help."
(2,647 Views)
I posted a response to your question in the FieldPoint Discussion Forum. Here is a link to that question:
Can't bind to the com port
(2,647 Views)
