can't connect raspberry pi 4 to labview 2020 community edition
I tried to connect raspberry pi 4 to labview 2020, but it can't connect, I have tried everything but still can't
Any suggestions??
(877 Views)
Hi fathur535,
Have you enabled SSH on your RPi?
Have you tried connecting using the IP address of your RPi instead of its hostname?
Also, make sure you've gone through Getting Started with Raspberry Pi and LabVIEW Community Edition.
Fort
(858 Views)
yes, I have done it, but still can't
(853 Views)
You can try running the hostname -I command on your RPi to make sure you're using the right address.
Would it be possible to try another shared network connection like your wifi instead of running a hotspot on your computer?
Have you re-checked that the password is indeed the one you set during the SSH setup in the RPi?
This thread might be worth taking a look if you haven't yet: Solved: Raspberry Pi connection with Labview - NI Community
Fort
(840 Views)
