can't connect to c-rio 9068
It says no critical updates, service packs or upgrades available. 😞
I may have to call tech support tomorrow. Seems like a weird problem.
Message 11 of 17
(804 Views)
Yes, but I believe there is something wich has to be done with the Host side. Good luck and please update once you get your problem solved.
Message 12 of 17
(802 Views)
I think I've got everything done with the host but I could be wrong. I will post what I find at some point.
Thanks for trying.
Message 13 of 17
(795 Views)
When the RT target is on the network can you ping the device from the command line?
Applications/Systems/Test
National Instruments | AWR Group
Message 14 of 17
(779 Views)
Yes, I can ping sucessfully.
Message 15 of 17
(768 Views)
I have found the problem and it is me.
I was under the impression that our development system included the real time module. It does not. Once I installed the evaluation copy of the module, it works. Now I just need to shell out the extra money for the module. 😞
Thanks for the help guys.
Message 16 of 17
(757 Views)
Finally you made it... 😇
Message 17 of 17
(750 Views)
