can't find DAQ assistant or other DAQ control templates in Labview 8.5
I can't find DAQ assistant under function, as what I did in 8.2. I wonder how I could control Daq then.~~
(2,802 Views)
When you upgraded to LabVIEW 8.5 from LabVIEW 8.2, make sure that you upgrade all of your drivers.  In order to use the DAQmx driver with LabVIEW 8.5, you need to install DAQmx 8.6.  The DAQmx VIs are located in the same palette as in previous versions of LabVIEW.
Respectfully,
Rob F
Test Engineer
Condition Measurements
(2,776 Views)
