can't find Microsoft Excel Object with W10 64 bite and Labview 2017 32 bite.
i have written a program before, but now it can't be used according to windows 10 upgrade.
i can't find the Microsoft Excel Object with this windows 10 .
could you please help to figure out the problem?
(2,213 Views)
Accepted by topic author Willa_Liu
I assume you have installed Excel on that computer!
But most likely the 64-Bit  version. While the underlaying DCOM technology in Active X would easily allow to invoke Active X interfaces across byte domains, most applications are not installed like that. You might have to try using LabVIEW 64-bit.
Rolf Kalbermatter  My Blog
(2,188 Views)
hi, thanks for your answer, I have installed the new labview 64 bit, and the problem solved.
(2,100 Views)
